Notices
Sponsored by: DashLynx
Help! how to disconnect fuel lines at tank?
Old May 14th, 2011, 5:13 PM
bills 98 wt1500's Avatar
Default Help! how to disconnect fuel lines at tank? SOLVED!
tank down, can't figure how to disconnect the lines from the sender/module?? not the usual plastic squeeze fitting
Update: got them. had to get this special tongs-like tool from Advance...only 7.00..
Old May 15th, 2011, 2:48 AM
buddy sabins's Avatar
Default fuel tank
its easier to raise the bed then drop the tank but since you dropped tank id cut hole in bed above tank nd weld hing to it trust me ive changed many pumps and that is simple if you plan on keeping truck a while and if you have a bed liner to hide door
Old May 15th, 2011, 11:49 AM
Glad you were able to get it, post a picture of the tool you used, it might save someone else some time and trouble...
Old May 15th, 2011, 10:28 PM
bigj2201's Avatar
i made the mistake of just pulling it off and every now and then it popsoff and fuel goes everywhere and i have to crawl under there and pop it back on wont do that again
rtarb41323
April 2nd, 2012 8:05 PM
Jodel
August 14th, 2011 1:45 AM
kevinf
November 16th, 2008 3:32 PM
jffgin
September 16th, 2007 5:42 PM
jffgin
September 8th, 2007 3:23 PM
Quick Reply: Help! how to disconnect fuel lines at tank?
