Help! no 4 wheel drive during 1st snow storm
On my 2001 2500 hd plow truck i pushed the 4x4 button and all i got was 5 flashing lights on the button and then it went back to 2x4 . I can hear an electric motor noise when i push it , at the transfer case just does not seem to engage . Any ideas where to start ?
Thanks
Thanks
could be a couple things... front actuator already talked about and also i read about the switch going bad in other posts. I have the same issue in my 04 2500. I'm on deployment right now to troubleshoot the issue.
Check ground wires under drivers door outside frame looking forward. Clean wires and frame and tighten securely. Check and clean all connectors on T/C, forward axle and dash switch. Good place to start.
