Notices
Idling issues
Old July 27th, 2009, 9:20 PM
Oregon Silverado's Avatar
Default Idling issues
1999 Chevrolet Silverado extended cab Z71 with a 5.3 liter.
<O
Problem-It starts fine when it is cold, and runs fine. As soon as it is warmed up, it hard starts. It takes about 7-10 turns to start, unless I hit the gas then it sputters and starts after about 4-5 cranks. Again, once warmed up it will start to stall at stops and occasionally it does stall.<O</O
<O
2 months ago the fuel pump went out on it, and I thought that it was it. So I had the pump, filter and relay changed, and it still does it. Any input to any ideas that you guys have would be so appreciated.
Thank you for looking!
Old July 27th, 2009, 11:27 PM
lukemoore646's Avatar
check the fuel pressure regulator vacuum hose, if it smells like gas then it is bad, i have seen them do this before
Old July 29th, 2009, 6:24 PM
Thank you so much! That was it, runs like new again
jbs6891
October 15th, 2013 3:17 PM
wrkinprogress
May 27th, 2010 9:02 PM
sprusgoose
December 4th, 2006 1:46 AM
weegie81
September 22nd, 2006 4:52 PM
bigal1985
May 9th, 2006 6:28 PM
Quick Reply: Idling issues
