missing when it rains hard
my 2000 3500 pu on the way to work it was raining hard and it started missing cut it off at work then it wouldn't start. It has done this before but uasally starts after setting for about an hour but not this time. It kind of sounds like it jumped time when you try to start it. but it only has 92000 on it. put a crank sensor on and didn't help.
Professional Mechanic
Sounds like typical bad plug wires. Wait until it is starting to get dark out, mist the plug wires with water from a spray bottle and look for sparks.
I don't know if your engine has the coil packs or a cap and rotor, but if its cap and rotor its very possible the cap is cracked and moisture is getting in.
gumbute
February 29th, 2020 11:26 AM
tlspirit
October 17th, 2010 9:13 AM
48fan
Silverado & Fullsize Pick-ups
14
January 20th, 2007 12:45 AM
48fan
Audio/Visual Electronics
December 29th, 2006 5:44 PM
