New member with a stalling question
Hello everyone! I just picked up a 92 1500 Tbi 5.7 and have a question about a problem I'm experiencing. The truck will start ok and soundssmooth while running, revs good in park with noexcess noise or vibration.When I put it in drive the idle drops and stalls out. When I try to start it again it will not fire and I get some vibration and noisefrom the drivetrain when it turns over (sounds like it could be coming from the tranny)?? It wont start unless I let it sit for a day or two then try again.Is there any common problems like this that these trucks have? Could the tranny be partially engaged still? Any ideas? Thanks in advance
RE: New member with a stalling question
So far only park. I've only had about 30minutes to play around with it. I will try neutral in a couple days when the weather improves. I thought I would also start with the cheapest things first vacuum leaks, pcv, Maf (I have a spare) ect? Any other cheap starting points?
bub2000sierra
Silverado & Fullsize Pick-ups
May 30th, 2012 10:15 PM
Zach3713
February 2nd, 2009 4:28 PM
mmjsport
14
December 8th, 2008 8:16 PM
98Silverado1500
January 6th, 2008 1:06 AM
