Last edit by: IB Advertising
See related guides and technical advice from our community experts
- Chevrolet Silverado GMT900 How to Clean a Faulty Mass Air Flow Sensor
Step by step instructions for do-it-yourself repairs.
P0172 & P0175 Codes
P0172 & P0175 Codes
Hey All, I have a 1998 Chevy K1500 Silerado with the 305 5.0L. I just changed the plugs, cleaned the throttle body, cleaned the maf sensor, and installed a cold air intake. Before all of this I would get a code for the maf sensor now and then. When I installed the cold air intake I had to add some wire to maf plug, about 3". The trucks runs a lot better with the new plugs. Now I get obd code p0172 & p0175 which is too rich on both banks.
The codes only seems to come up at lower speeds, 35-40 mph and not at the higher speeds. I can smell gas at times when I come to a quick stop.
I have been told that the wiring might be the problem, because I used butt connector's, and they have a lot of resistance.
My thought is that the cold air intake is not getting enough air at the lower speeds.
Any ideas???
Any ideas???
Sarah18
Silverado & Fullsize Pick-ups
August 19th, 2013 5:51 PM
SanDog11
November 28th, 2012 9:17 PM
