swapping axels?
swapping axels?
i have a 94 chevy k1500 and i blewup my rearend. im looking at a set of 94 k2500 8 lug diesel axels. does anyone know if they will boltup the same or if i need to do any modification
yea if the u-joints are different i can probably fix that at the autoparts shop or a driveline shop. I'm hoping everything else is the same though such as the upper and lower control/a arms and fitting in the same as the stock axels.
The guy has the whole frontend cut the frame just in front of the cab but i dont really want to weld anything just hoping to bolt it together.
also does anyone know a good site to get ring and pinion gears and what brand would be stronger?
thanks for all the help so far
Ride of the Month
May 2009
Ride of the Month
May 2009
I don't think the knuckles would work, I think you woud need to weld new mounts on for the contol arms. You can order gear sets at http://www.ringpinion.com/ that's where I have bought mine. The Yukon gears are good ones.
I just remembered that the light duty 3/4 ton with the 6 lug axles will bolt in, but they use the same 8 1/4 front diff and CV's as the 1/2 ton.
05chevy4x4
Silverado & Fullsize Pick-ups
December 11th, 2007 6:26 PM
redpeppers
December 7th, 2005 12:55 AM
