Notices
Sponsored by: DashLynx
Trying to Bleed Rear Brakes and no pressure
Old June 13th, 2012, 6:49 PM
  #11
I did a search for proportioning valve tool. The link below shows what it looks like.
DriveWerks.com - Proportion Valve Depressor
Make sure you truck even has this j block; some don't.
Old June 15th, 2012, 4:06 PM
  #12
KGJC616's Avatar
so this is what is all looks like right now. is there anywhere that i can buy the silver proportioning/combination valve and how much do you think it might cost? i think i might have striped out the back threads on the proportion/comb valve.
Attached Thumbnails Trying to Bleed Rear Brakes and no pressure-master-front.jpg   Trying to Bleed Rear Brakes and no pressure-master-side.jpg
Old June 15th, 2012, 4:29 PM
  #13
kevinkpk's Avatar
Threads or the flats on the nuts? You might need a line wrench to fit your B nut. You can start with bench bleeding the master cylinder, then reinstall it with the porportioning valve, then bleed to the rear, then front brakes.
Old June 15th, 2012, 7:26 PM
  #14
KGJC616's Avatar
I have line wrenches. but its not the nut its the threads inside the vavle.
Old June 15th, 2012, 7:39 PM
  #15
kevinkpk's Avatar
Check salvage yards, or if you have a national parts store line available, check them for a new valve.
blazerhazer
June 8th, 2015 9:19 PM
GL Floyd
June 16th, 2014 2:25 AM
Inside&Out
March 18th, 2014 7:30 PM
crbav8r
September 28th, 2010 6:37 PM
300winchester
January 8th, 2010 10:36 AM
Quick Reply: Trying to Bleed Rear Brakes and no pressure
