Wet carpet front and rear passenger side
#12
#13
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Where you able to resolve this issue? If so, what was the resolution? If not, if you pm me your name and VIN, I can research this issue further if you would like. I look forward to hearing from you.
Louis
GM Customer Service
Louis
GM Customer Service
#14
Louis,
I am pretty certain the leak is in the windshield seal area. Came out to the truck the other morning after a good rain and there was water inside, now I just have to isolate the leak and figure out a repair. Florida has free windshield replacement so I may go that route. Thanks for the response, I will keep your address around for future issues if you dont mind.
#15
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> UsNavyChief,
I am happy to hear that you have figured out the reason for the leak. If you ever have any questions, feel free to contact me. Best of luck with the repairs.
Louis
GM Customer Service
Louis
GM Customer Service
#16
Louis,
#17
Having the windshield replaced on ednesday, will update on the leak. No whow about the high pressure port on the AC line, charging the AC with a can of 134 th eother day and when I removed the high pressure port plastic cap (becuase I head a hiss) it seemed like all the 134 I put in was coming shooting stright up in the air from the high pressure port. Can the valve core in those ports be changed or do I have to change th eentire port or maybe even the line. Thanks again for all the great info
#19
I know this is an old thread but I just joined here looking for solutions and wanted to share my discovery..
My leak was due to the wiring boot shrinking between the body and the door jamb due to age.
I removed the boot on the body side and applied some clear Silicone.The leak is cured and the carpet padding has remained dry.
Only the passenger side has a plate below the hinge inside the kick panel that can trap and cause water the migrate to the padding.
My truck is a 2000 model.
#20
2002 Chevy silverao
Wet passenger n rear passenger seat
Louis
GM Customer Service
Louis
GM Customer Service
nwagtmustang
March 27th, 2014 12:47 PM
