'00 silverado ABS and Brake light
Old Sep 22, 2009 | 11:14 AM
mingito's Avatar
Default '00 silverado ABS and Brake light
My ABS and Brake light stays on when I'm driving. I'm thinking its the sensors. How do I get the lights to stay off?
Old Sep 22, 2009 | 1:42 PM
therewolf's Avatar
This may because you need some brakes. When was the last time they were done?
You may need to disconnect your battery, clean your ABS plug connector, and reconnect it in 15 minutes.
Old Sep 22, 2009 | 6:28 PM
silverado08's Avatar
I got rid of a 2000 silverado z71 bout 2 months ago. one of my front abs sensors was bad and causing the brakes to not work at low speeds. So i pulled the abs fuse out. By doing that my brake and abs light came on.
Checking the fuse first would be ur best bet then new sensor. sensors are only $50 and take bout 30 minutes to change
Old Sep 23, 2009 | 9:41 PM
mingito's Avatar
I just changed my brakes about 4 months ago. The lights turned on after I changed them.
Theguywithanswers82
Apr 29, 2015 2:17 PM
kaptain howdie
Dec 16, 2014 8:20 PM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
