04 chevy instrument panel stopped working!!
Old Nov 30, 2008 | 2:01 PM
mcdaddy47's Avatar
Default 04 chevy instrument panel stopped working!!
Hellogents I hope someone can help me with a problem I have .I own a 04 Chevy Sliverado pickup with 83,000 mileson it and never had a problems with it till today . I went out to start it and notice after I started it I had no gauges or speedo and park indicator was not working but it stated and drives just finebe no way to know if you have a full tank or if its over heating or oil perssure. I checked all fuse inside the cab and under the hood all cheched ok with a test light . thanks for any help .
mcdaddy47
Old Nov 30, 2008 | 5:50 PM
ukrkoz's Avatar
Default RE: 04 chevy instrument panel stopped working!!
search around, there's word about GM recall on those.
Old Dec 1, 2008 | 6:21 PM
CaptTrevStarr's Avatar
ditto....just what i was goin to say....check it out..THERE WAS A RECALL of some sort with guages!!
capt
Old Dec 2, 2008 | 12:51 PM
Bertha's Avatar
About half a year ago, I got a letter from GM saying there wa reported problems with the cluster of 2004 Silverado's. It stated that if I was having problems with hesitation in the gauges or they weren't working at all, to take it into my GM dealership and it'll be fixed with no charge. Shortly after that I noticed my RPM gauge would hesitate and jump, even though my engine was running normally. I took it into my dealership and they just replaced my dash cluster.
Old Aug 15, 2013 | 3:57 PM
Keely Winn's Avatar
Does this recall of the instrument panels pertain to 1992 chevy s10?
Old Aug 16, 2013 | 3:35 PM
The recall is only from 2003 to 2006. No luck with the S10. I had a 03 Trailblazer with the cluster problem and they would not fix it either. They said the Trailblazer was not recalled.
Old Aug 16, 2013 | 11:28 PM
JK23112's Avatar
Default Instrument Panel Recall
Does the "recall" cover an instrument panel if the voltmeter is not working at all and the tach fails about ten percent of the time? If so, does it have to be a Chevy dealer or can a GMC dealership handle it?
Everything else is okay, though.
Old Aug 17, 2013 | 8:34 AM
Any GM dealer should be able to do the repair if the vehicle has a recall on it. If not the cost is around $600.00 at the dealer.
apoks10
Dec 4, 2014 7:53 PM
randykersker
Apr 4, 2014 3:21 PM
ookami
Feb 15, 2009 11:21 AM
05 Z71
Oct 9, 2007 6:47 AM
