05 rear brakes
Old Jun 8, 2009 | 1:33 AM
racerx55's Avatar
Default 05 rear brakes
ok, so ive had enough of the rear drums going out of round, replacing them at $100 each and them lasting untill i tow my trailer and theyre oval again.
shoot me some suggestions, should i just find an 06 axle and put under it ( since they are rear disc) or does someone make a decent conversion? i honestly dont know if i would need to change the master cyl or not....
I tow on alot of hilly and curvy roads and these brakes just arent cutting it at all.
Old Jun 8, 2009 | 8:53 AM
bad2006z71's Avatar
06 half ton axles are drums. 05-07classic recieved drums.
Old Jun 8, 2009 | 5:39 PM
racerx55's Avatar
i meant 04 axle... was pretty late haha.
either way i need to get rid of these drums they are junk.
Old Jun 9, 2009 | 7:10 AM
bad2006z71's Avatar
im sure its a little bit invovled to change them over. the rears on your truck are "dynamic rear portional" whatever that means. im not really a brake guy.
good luck
Old Jun 9, 2009 | 10:53 AM
therewolf's Avatar
One of the major differences between the 1/2 ton and the 3/4 ton truck is larger brakes.
The 2500HD models come with rear disc brakes standard. If you do swap rears, you'll be dealing with different tire sizes, and the small problem of updating your PCM with your new specs.
Sounds like drum brakes don't agree with your trailer. Maybe you could find out if you can get a set of rear disc brakes for a 1500.
Old Jun 9, 2009 | 6:12 PM
racerx55's Avatar
like i said, disc conversion or an 04 half ton axle with rear disc.
im still pissed to this day that i had to get rid of my 07 2500HD.
JRich_taco
Aug 31, 2013 12:16 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
dueceman
Aug 23, 2006 9:41 PM
paul steele 72
Jul 18, 2006 10:31 AM
rbcyouthdude
Jun 8, 2006 4:09 PM
