1500 Chevy Isn't switching gears anymore
Okay we have a 2002 chevy 1500 silverado, a few months ago we started hearing banging in the so we thought rear of the truck but after some looking around we found a hole in the transfer case so we took it out and had it repaired but when it was taken on a test drive it would shift out of 1st gear and the speedometer stays at 0
We did find that one of the wires going to the (speed Sensor on the Transfer Case) wasn't getting power as it's supposed to but we can't find anything wrong with the wire.
All the fuses were checked (4) different places correct? but they were all good or at least we didn't see any fried ones
The ones that weren't getting power when they were in place we took out and sent power through and they worked.
There is also one pipe little rubber pipe above the transfer case that looks cut and we have the end for it but we don't know what it is or where it goes.
If you can help please comment.
also the rubber pipe is for a breather vent, its supposed to be connected in line with the trans i believe not sure as i havent done one in awhile. but it is supposed to be conected to at least a check valve. if you call your local dealer they can fax you or print you off a diagram of the vent tube routing for free
oh okay wow Thanks everyone so much for all the answers i wasn't expecting that.
And I will be sure to try what you guys said. and like Joe and allan said the sensor makes its own signal I didn't know that. that could solver a few problems but still why would it have gone bad right as we change the transfer case.
I guess someone could have ruined it actually..
ddescalso
January 10th, 2010 2:34 PM
