16 inch to 17 inch wheels 99 Silverado
Old Sep 17, 2010 | 10:18 AM
Aluminator's Avatar
Default 16 inch to 17 inch wheels 99 Silverado
If I went from the stock 16 inch wheel with 265/75/16 tire to a 17 inch wheel with the 265's would there be any issues besides the possible speedo being off?
Old Sep 17, 2010 | 12:10 PM
country_09's Avatar
what size is the tire on that 17? nothing should be wrong it'll make the truck look better but you'll have to get the speedo corrected
Old Sep 17, 2010 | 12:26 PM
gfd749's Avatar
is 265 the stock width. if 265 is wider than stock u will not only lose some turning radius but u will have to watch out for hitting hard bumps because it would be easier for the finder to cut into the tire. by hard bumps i mean harder than normal. nothing in daily driving u would have to worry about
Old Sep 17, 2010 | 12:33 PM
Aluminator's Avatar
I would have to go with a 275/70/17
Old Sep 17, 2010 | 12:35 PM
Aluminator's Avatar
The 265 was on it when i bought the truck Tire Rack gives 2 options with the 16 inch 245 and 265. I would have to go with a 275/70/17 with the 17 inch rim.
Old Sep 17, 2010 | 5:43 PM
jcgonzal's Avatar
I'm doing a similar mod, except I'm going with stock '06 Tahoe rims, so the width is still 265.
Old Sep 17, 2010 | 7:24 PM
country_09's Avatar
other than the speedo bein a lil off (it wont be off by much) my truck came with 265s and now i've got 33x12.5x20s on it and had a buddy drive next to me with stock tires and rims and my speedo was off by 7 at 65, only other thing you should worry bout is turnin if it'll rub or not
Old Sep 17, 2010 | 8:59 PM
JK23112's Avatar
My 2004 Silverado 1500 2wd had 16" rims, but a previous owner put 17" (GM 4x4 rims) wheels on it. The tires are 265-7017 and my speedometer is off by 2 or 3 mph, depending on speed. If it reads 72, I am traveling 75 mph.
Aside from looking like a 4x4 from a distance, the truck rides normally. It has Goodyear rubber, but I'll probably replace them with Michelins in December when my state inspection is due. My current tires have a bit of tread remaining, but I don't want to take chances with my truck only being rear-drive. (It's like a duck on ice when I try to drive it in snow.)
P.S. To check your speedometer accuracy, I know of three ways to do it. First, get a cop to measure your speed with radar. Second, use a mile marker and time the number of seconds it takes to get from one to the other at 60 mph, which should be 60 seconds if you cover exactly one mile. Third, use a GPS while driving a fair distance at a set speed. The GPS readout should match your truck's speedometer.
upsidedown
12
Jan 27, 2013 1:19 PM
lcampbell
Oct 28, 2012 7:08 PM
ashetzel
13
Mar 24, 2010 6:42 AM
chevysilverado2001
Dec 28, 2009 6:12 PM
Tahoeguy2
Apr 22, 2007 5:08 PM
