1988 4.3L ajusting roller hydraulic lifters
Old Apr 21, 2010 | 8:30 PM
rmitch47's Avatar
Question 1988 4.3L ajusting roller hydraulic lifters
Hello, I just bought new small block and heads w/valve, spring, push rods and roller lifters(NO Rockers)! We got it all together and now I have no clue how to adjust these hydraulic lifters! Dont mean to sound like such a newb but this has me puzzled. All I can find is info on adjusting v8's hydraulic lifters . I need some info on adjusting this v6 4.3L, can anyone help me out, I really want to get this truck up and running! Thanks Rmitch47
Old Apr 21, 2010 | 8:43 PM
MDTAHOE's Avatar
Professional Mechanic
Remove rocker arm covers as described under COMPONENT REPLACEMENT AND REPAIR PROCEDURES/ROCKER ARM & PUSHRODS.
Crank engine until mark on torsional damper is aligned with ``0'' mark on timing tab and engine is in No. one cylinder firing position. Ensure engine is in No. 1 firing position by placing fingers on rocker arms of No. 1 cylinder as timing mark approaches ``0'' mark. If rocker arms are not moving engine is at the No. 1 firing position. If rocker arms are moving, engine is in the No. 4 firing position and should be rotated one revolution to the No. 1 position.
Adjust the following valves with the engine in the No. 1 firing position: exhaust 1, 5 and 6; intake 1, 2 and 3. Adjust valves by backing off nut until lash is felt at the pushrod, then tightening nut until all lash is removed. This can be determined by rotating pushrod while tightening nut. Fig. 14. When all lash is removed, tighten nut one full turn to center pushrod in lifter plunger.
Crank engine one full revolution until mark on torsional damper and ``0'' mark on timing tab are aligned. This is the No. 4 cylinder firing position. Adjust the following valves: exhaust 2, 3 and 4; intake 4, 5 and 6.
Install valve covers and related components
Old Apr 21, 2010 | 9:33 PM
rmitch47's Avatar
Hey thanks for the quick response! Im going out there right now to set it up. I cant believe how hard it was to find this info on the web. LOL Again thanks alot, Rmitch47
Old Apr 23, 2010 | 11:02 AM
rmitch47's Avatar
Question
well got it adjusted and now it has rough idle, poor acceleration, and I have timing mark set! Should I readjust the rocker after truck is heated up? btw I reguilt the carb to. The brake light stays on all the time and servive engine light comes on to! Im at a lost can you give me some advice, sorry for all the questions. thanks rmich
Old Apr 23, 2010 | 9:35 PM
MDTAHOE's Avatar
Remove the valve cover and start the truck. One be one loose the valve until it taps then tighten it 1 turn. I would be more suspect of the carb then the valves is you adjusted them like it says
Old Apr 24, 2010 | 8:35 AM
rmitch47's Avatar
Thumbs up
Will I think we found the problem! We put new plugs and distributor cap and that leveled it out alot and just heard that that engine has a line to computer that has to be unhooked before the timing is set. Thanks for you input and if you think of anything else, please let me know. Thanks Rmitch37
Old May 7, 2010 | 9:04 AM
rmitch47's Avatar
hey well we got it all taking care of and now we cant find info on the timing setting? Is it 6degrees or zero? Thanks
Old May 7, 2010 | 10:55 PM
MDTAHOE's Avatar
The spec is 0 degrees.
1956midwaywagon
Feb 8, 2011 1:05 PM
jason.t.h
Jun 6, 2010 3:48 AM
builtchevy1
14
Jul 12, 2009 10:36 PM
LTD10
Apr 2, 2008 4:30 PM
