1988 light duty k2500 350 5.7l not getting fuel to throttle body
I have an 88' k2500 5.7l 350 that is not getting fuel to the throttle body. at first i figured it was the fuel pump so i took the tank out and replaced that, after replacing, cycled the key five times and it started up for about ten seconds and then sputtered and died. i was like ok lets check injector signal, so i did that and there's no problem there, next i checked the relay, it was good and even when i had the connector for the relay jumped and confirmed that the fuel pump was running it still will not run and is not getting fuel to the throttle body, where do i go from here? im completely stumped.
Did you check the injector resistance? one shorted injector will cause neither one to open, yet when you do a pulse test with them unplugged it checks out normal.
there is gas in the tank right? lol
just checked resistance, reading 1.5 ohms, according to factory specs thats good. and yes there's over half a tank in it. WHAT THE **** THIS TRUCK IS PISSING ME OFF!
Sounds like something is grounding out. I would put a test light on the fuel pump wiring. Did you prime the new pump. Also test the pressure too.
sitsonhisbutt
April 25th, 2013 10:01 PM
gdavies07
November 7th, 2011 11:47 PM
thomaslea1
February 6th, 2008 10:42 AM
Mosination
October 5th, 2006 2:37 PM
