1988 light duty k2500 350 5.7l not getting fuel to throttle body
Old Nov 28, 2009 | 3:18 PM
88k2500's Avatar
Default 1988 light duty k2500 350 5.7l not getting fuel to throttle body
I have an 88' k2500 5.7l 350 that is not getting fuel to the throttle body. at first i figured it was the fuel pump so i took the tank out and replaced that, after replacing, cycled the key five times and it started up for about ten seconds and then sputtered and died. i was like ok lets check injector signal, so i did that and there's no problem there, next i checked the relay, it was good and even when i had the connector for the relay jumped and confirmed that the fuel pump was running it still will not run and is not getting fuel to the throttle body, where do i go from here? im completely stumped.
Old Nov 28, 2009 | 3:26 PM
nauticstar87's Avatar
Check for crimped fuel lines and change the fuel filter
Old Nov 28, 2009 | 5:28 PM
88k2500's Avatar
forgot to add, i changed the fuel filter when i took the tank out, no crimped lines have already checked those.
Old Nov 28, 2009 | 6:11 PM
racerx55's Avatar
Did you check the injector resistance? one shorted injector will cause neither one to open, yet when you do a pulse test with them unplugged it checks out normal.
there is gas in the tank right? lol
Old Dec 1, 2009 | 11:13 AM
88k2500's Avatar
just checked resistance, reading 1.5 ohms, according to factory specs thats good. and yes there's over half a tank in it. WHAT THE **** THIS TRUCK IS PISSING ME OFF!
Old Dec 1, 2009 | 3:00 PM
Its possible the injectors are clogged, if you haven't done it already unhook the fuel line at the TBI and see if fuel is getting that far.
Old Dec 2, 2009 | 9:09 PM
cowboy888's Avatar
i just replaced my fuel pump and it is bad. i had to turn my key off and on 5-10 times. after i replaced it runs fine.
Old Dec 3, 2009 | 5:03 PM
davbell22602's Avatar
Sounds like something is grounding out. I would put a test light on the fuel pump wiring. Did you prime the new pump. Also test the pressure too.
indoorairpro
Jul 21, 2014 8:13 PM
sitsonhisbutt
Apr 25, 2013 10:01 PM
gdavies07
Nov 7, 2011 11:47 PM
thomaslea1
Feb 6, 2008 10:42 AM
Mosination
Oct 5, 2006 2:37 PM
