Old Aug 10, 2015, 7:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
1990 Silverado Wiper Problem
Old Apr 1, 2011 | 3:04 PM
Haner's Avatar
Default 1990 Silverado Wiper Problem
I have a wiper problem and have narrowed it down to the pulse module. My problem is the pulse module in my truck is an older rectangular model, not the 'C' shaped one that is readily available at stores and on the net.
Does anyone know how to obtain or repair this older model pulse module?
Thanks.
Attached Thumbnails 1990 Silverado Wiper Problem-pulsemodule2.jpg   1990 Silverado Wiper Problem-pulsemodule3.jpg
Old Apr 1, 2011 | 7:42 PM
Hunt4X4's Avatar
i had the same problem and got a new one at NAPA
Old Apr 1, 2011 | 8:33 PM
Rob G's Avatar
I had a wiper problem recently...but....it sort of fixed it self.
Could you share what your symptoms were? or did they just stop working.
Let the kids drive through big mud puddles in the woods on a weekend getaway, wipers would not turn off. pulled the fuze and re-installed when I had to drive in the rain.....about a week later..the wipers started to work normally.
Old Apr 2, 2011 | 12:09 PM
Haner's Avatar
Hunt,
Do you have a part number?
Rob,
Wipers wouldn't stop, sometimes, when in intermittent mode. It's funny, but when they'd get 'stuck' they would cycle 13 to 14 times and then stop; sometimes in the middle of the windshield. Washer pump wouldn't work either.
I just took the module out and cleaned all the contacts and coated them with dielectric grease. My hope is that better contact will keep things working. So far so good.
I did find a place that will repair it for $40 plus shipping in Rialto California. It's called Nyco. They repair industrial electronics. I have a feeling this Delco module may have been used in nonautomotive applications. That's just speculation, though.
Old Apr 2, 2011 | 12:45 PM
Rob G's Avatar
mine wouldn't stop either, even when toggled through all the intermittent cycles...they would stay the same speed or stop an start intermittingly. When I switch to off...they would keep running.
My squirter still worked the whole time though. Thanx for the info , though, something to look out for!
Old Apr 2, 2011 | 1:37 PM
Haner's Avatar
Here's the link to that repair company I mentioned, just in case anyone is interested.
Industrial Electronics Services - Repair, Engineering, Testing | NyCo-Systems
Old Apr 3, 2011 | 8:39 PM
BamBam's Avatar
Sweet on that link. I have a plasma cutter motherboard I need to get intouch with them about repairing. Miller wants almost as much for the board as what the machine is worth new
Old Aug 30, 2011 | 9:20 AM
flh69's Avatar
Originally Posted by Haner
Hunt,
Haner,
Did you ever get a part number? I have a 1990 with the same module and the same problem but can not find the module.
Old Aug 31, 2011 | 10:14 AM
Haner's Avatar
Originally Posted by flh69
Haner,
Nope. Never got the NAPA part number. I suspect the NAPA module is the same one available as the current and readily available one. But, I have to tell you that coating the contacts on the module with dielectric grease solved my long running problem. The wipers have been working well for four months without a hiccup. I suggest you give this a shot before pulling your hair out trying to find a replacement part.
Get the grease at any auto parts store. Just ask for the grease that is used on electrical contacts. Using this stuff also fixed a problem I was having with my tail lights working intermittently.
If the grease doesn't work, follow the above link to Nyco Systems. They will fix the module for around $100.
Old Aug 31, 2011 | 10:36 AM
flh69's Avatar
Yea, the NAPA one is the "c" shaped one that you can buy anywhere. I'll give the dielectric grease a try.
I've looked at the Nyco website and if it comes down to that, I may just replace the motor and module with the available one. It would not be that much more expensive.
I just wonder what motor & module we have. It must be a real "bastard" setup as there are no replacements for it.
