1991 Chevy Silverado Brake Cylinder Leaking
Old Dec 23, 2014 | 2:47 PM
GregHamilton's Avatar
Default 1991 Chevy Silverado Brake Cylinder Leaking
Hello,
My son's 1991 Chevy Silverado's master brake cylinder is leaking. There are two seperate reservoirs. It is the one towards the front of the truck. Does one of these reservoirs feed the front wheels and one the back? We don't see any leaking underneath the master cylinder or booster. Just trying to figure out the quickest way to identify the leak. Thanks.
Old Dec 24, 2014 | 9:46 PM
mel902's Avatar
Check your brake lines first,then calibers if you do not see any drips or spots on the ground underneath the truck.If the fluid is dropping it has to be going somewhere.
Old Dec 26, 2014 | 1:17 PM
That makes sense. Thanks. I just figured one of the reservoirs was for front and one was for back but couldn't find any documentation confirming this.
Old Dec 27, 2014 | 8:09 AM
mel902's Avatar
Here is a simply example of how brakes works and will answer your question on your reservoir.
Automobile Brakes - A Short Course on How They Work | CarParts.com
A typical master cylinder is actually two completely separate master cylinders in one housing, each handling two wheels.
Old Jan 1, 2015 | 3:01 AM
Could see fluid dripping on inside of right rear tire. Pulled wheel and brake drum cover, could see dripping from wheel cylinder. Replaced same for less than 20 bucks and bled the brakes and good to go. Thanks.
Old Jan 1, 2015 | 6:13 PM
mel902's Avatar
Your welcome.Glad you got it figured out for such a good price.
Old Jan 2, 2015 | 2:56 AM
Yeah, me too. Thank you.
jason78
Apr 13, 2014 2:40 PM
Chris9793
Jan 3, 2014 7:50 PM
tom5170
Oct 24, 2010 11:22 PM
tom5170
Apr 17, 2010 3:10 PM
