1992 Chev 2500 almost stalls when braking
Hi everyone, first post on the board so thanks for listening. Ive got a 1992 3/4 ton with a 350 5 speed that seems like it wants to stall whenever i put in the clutch and roll up to a stop sign. The rpms drop to about 100 and then climb back up to normal but it doesnt sound good and makes me nervous if Im in traffic. I can be driving on the highway doing 80 and if i put the clutch in and let off the gas it seems to do the same thing so Im at a loss. Ive had the TPS replaced, the IAC cleaned, new filters and gaskets in the TBI system, fuel filter changed. If anyone has any ideas Im open to all suggestions. Thanks!
I had the same problem on my 350 tbi automatic. when i let off the gas it would bog to about 100 rpms then recover. real annoying. I replaced the TPS and ECTS and it did nothing. It seemed to only do it once the engine got warm. brought it into a shop, they unhooked the egr. said it was faulty. now it doesnt do it anymore
i dont know how they did it either. the check engone light inst even on. they said i should get a new one however.
Thanks for the replies. I have a brand new battery and alternator and its charging fine. Im curious about the EGR so Ill have to have a look and see if I can wither disconnect it or get a new one. Thanks
I am glad my model didnt come with EGR, got in Texas. EGR is like a human that smokes, it just slows you down physically
You need it for a smog inspection though in most states.
webby00011
Jan 21, 2015 7:47 PM
dhertzog4349
Jul 8, 2010 9:14 PM
Sevens
Jan 29, 2009 10:06 AM
no check engine light either. will it hurt anything to run it without an egr hooked up?
