1993 350 TBI will not start. Help Please
![Thumbs down](https://chevroletforum.com/forum/images/icons/icon13.gif)
I changed the IAC,Fuel Pressure Regulator, Inline Fuel Filter,andFuel Pump.
The only code that i get through the ALDL is 12. Which if im correct is stateing that its in testing process, i let this run for 21 times before i shut it off and cleared it. Ran it again and still 12 comes in, all this is done with motor off of course since its dead!![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
Please any help would be appriciated,Newbi here!
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
do you have good spark,can you see fuel being sprayed out of the injectors,did it jump timing line up #1 cylinder at TDC and make sure the rotor is at #1 post on the distributor
Sean
97 4x4 burb
Sean
97 4x4 burb
catchmeifyoucan
May 7th, 2014 5:56 PM
simpsonracing
March 19th, 2013 3:37 PM
computerdude14
January 8th, 2013 3:33 PM
Dylly
August 6th, 2011 7:10 PM
