1993 K1500 5.7L 4L60E transmission problems
Old Feb 20, 2013 | 12:39 PM
93K1500's Avatar
Default 1993 K1500 5.7L 4L60E transmission problems
Hello all
I have some problems and was wondering if someone can maybe help me. My transmission is having problems. Im going to try and explain this the best as i can. I hear a weird noise in 2nd gear, slip/grind noise. This noise only happens in 2nd. If i put the truck in {R} reverse it works perfect. Put the truck in [D]Dover driver it works perfect unless shifts to 2nd gear. Put the truck in {d} drive it works perfect unless it shifts to second. If i put the truck in {1} the truck drives perfect. But if i go right to {2} 2nd gear the truck do not want to move and when u do get it to move you hear a grind like metal on metal noise coming from the transmission. I dont know if it can be the 1-2 solenoid not pushing enough fluid to run 2nd, If the sun shell is gone. or if the planetary gear is gone. I am going to do the rebuild myself but i want some input before i tear it apart to see what exactly it could be. and if i dont have to tear it apart i would like that even better. Please give me some ideas what it can be and if you think it needs to be rebuilt or not.
Old Feb 20, 2013 | 4:53 PM
Allan In NE's Avatar
Yep,
Go no further and pull 'er down outta there.
You're gonna find the problem in the reverse input drum. What its' doing is trying to run in two gears at once and something's gotta give. That "give" is your grinding noise.
Allan
Old Jun 18, 2014 | 11:29 AM
Shoogieboogie's Avatar
the speedometer does not read correctly on my 1993 Blazer Silverado 5.7 4x4 and the trans does not shift right. Is the transmission controlled by the ECM?
Old Jun 18, 2014 | 1:00 PM
Yes, common item there is the Vehicle Speed sensor.
Allan
Old Nov 17, 2020 | 4:54 PM
Stephen Tyler's Avatar
Default Stops pulling
They other day I drove my 93 k-15 blazer to the store nothing wrong it get back in it after coming out the store it will not move when I put in gear but you can let It set and cool off and put in gear it will be fine it it gets hot
Old Nov 17, 2020 | 6:42 PM
PNW NBS Z71's Avatar
Welcome to the forum from Oregon.
Are you sure that is a 4L60E? Does it have RPO code M30 on the glove box cover? Is it maybe a 700R4? I could be off by a few years though.
Old Nov 17, 2020 | 10:04 PM
It is a 4l60e in it but I do got a good 700r4
Old Nov 18, 2020 | 12:47 PM
I am still not understanding your answer. Do you have the M30 RPO code or not? Was the original trans a 700R4 or the 4L60E?
runge_24
Apr 9, 2014 1:23 AM
Pwadwa2012
Dec 15, 2013 10:24 PM
abqgolfer
Aug 27, 2011 11:30 PM
SolomonMan
Jul 25, 2011 8:27 PM
chadb2008918
Feb 23, 2009 11:50 AM
