1995 C1500 Tranny Pan Gasket
I'm needing to change the tranny pan gasket on our 1995 Silverado C1500 ext. cab w/auto transmission & 2 wheel drive. I can tell the gasket is leaking on the back side.
I have never replaced one before but have experience working on vehicles. My question is how can I remove the bracket supporting the transmission so the back pan bolts can be removed? It has a stud coming down from the tranny through the middle of the bracket. I can see 2 other bolts attached to transmission housing which might let the bracket slide out but not sure what I should or shouldn't take loose.
Or, is this a job better left to a professional? Doesn't look like it is that hard of a job once the bracket is removed.
Thanks.
Thanks.
Thanks.
Thanks.
fishfun83
October 22nd, 2009 7:08 AM
