1995 C1500 Tranny Pan Gasket
Old Oct 29, 2011 | 11:33 AM
ChaseC's Avatar
Default 1995 C1500 Tranny Pan Gasket
I'm needing to change the tranny pan gasket on our 1995 Silverado C1500 ext. cab w/auto transmission & 2 wheel drive. I can tell the gasket is leaking on the back side.
I have never replaced one before but have experience working on vehicles. My question is how can I remove the bracket supporting the transmission so the back pan bolts can be removed? It has a stud coming down from the tranny through the middle of the bracket. I can see 2 other bolts attached to transmission housing which might let the bracket slide out but not sure what I should or shouldn't take loose.
Or, is this a job better left to a professional? Doesn't look like it is that hard of a job once the bracket is removed.
Thanks.
Old Oct 29, 2011 | 2:46 PM
kevinkpk's Avatar
Thanks.
Bracket? Are you refering to the crossmember?
Old Oct 30, 2011 | 10:07 AM
OLD WRENCH's Avatar
You will have to jack the trans up to get the mount out. Just dont go crazy with it.
fishfun83
Oct 22, 2009 7:08 AM
cleft_asunder
Oct 17, 2009 11:36 AM
fazdaboy4ever
Sep 30, 2009 5:52 PM
markjw
Dec 2, 2008 4:28 PM
paulk
Feb 11, 2006 2:20 AM
