1995 Chevrolet Silverado Truck - Need Help!
Old Nov 21, 2008 | 2:34 PM
skeetern01's Avatar
Default 1995 Chevrolet Silverado Truck - Need Help!
I have a 1995 Chevrolet C1500 5.7L, 2wd, automatictruck that has an intermittent SERVICE ENGINE LIGHTthat comes on when the truck is in PARK. It goesoff when you increase the RPM's. Truckis idelingbetween 900 -1000 RPM's in PARK. Have not ever seen light come on when in DRIVE. When stopped at a light with truck in DRIVE, the RPM range is between 700-800 RPM's.
Been to AutoZone and was told the code indicated the Air Intake Control sensor (IAC)needed to be replaced. To date I have replaced it twice, and still have thesame problem. Replaced the Throttle Position Sensor (TPS) also. All electrical connections appear to clean and good. No apparent vacuum leaks.
Need to resolve to get inspected.
Thanks!
Old Nov 21, 2008 | 3:54 PM
shawnvw's Avatar
Banned
Default RE: 1995 Chevrolet Silverado Truck - Need Help!
If it is a TBI, check for vacuum at the PCV valve. If there is none, buy a throttle body gasket and take the throttle body off and clean all the carbon out of it
Old Nov 21, 2008 | 4:06 PM
skeetern01's Avatar
Thanks for the great advice. The truck does have a TBI and A/C. I replaced the EGR valve about a year ago, but will test it. I have sprayed the TBI with cleaner, and there are no misfire codes to date.
Old Nov 21, 2008 | 4:14 PM
skeetern01's Avatar
Thanks for the suggestion. There is good vaccum from the PVC valve. I have had the thought to remove the TBI and break it down to clean. Have not looked into securing a gasket set.
Old Nov 25, 2008 | 7:03 PM
mudmaniac's Avatar
Ride of the Month
May 2009
When you replaced the TPS did you check and adjust the voltage output at idle and WOT ?
Tahoetrucken
Oct 14, 2015 12:28 PM
Tahoetrucken
Aug 13, 2014 11:34 AM
bmxpro67
Jan 18, 2011 11:08 PM
rlopez
Dec 9, 2008 3:41 PM
hesreallygood
Nov 7, 2007 6:25 PM
