1995 chevy 1500 truck wont shut off
Old Sep 4, 2013 | 9:07 PM
chevy350ga's Avatar
Default 1995 chevy 1500 truck wont shut off
Ok i recently pur a used motor in my truck but when i hooked the battery back up everything turned on like the key was turned on but the switch was off and when i started it i could out shut it off so i just put in a battery cut off switch but now my truck wont start i can get too start by mashing the gas but i have to keep hitting the gas till it smooth out but it acts like it skipping but i just put new spark plugs and rotor but it did help
Old Sep 4, 2013 | 9:58 PM
The engine is wired incorrectly.
Old Sep 5, 2013 | 8:16 AM
chevy350ga's Avatar
Well I've had 3or4 guy look at it even looked at another trucks to c if it was wrong but everthing is were it need to be
Old Jun 18, 2015 | 10:27 PM
95YukonGT's Avatar
Default Same issue
I'm having the same issue after pulling my 5.7L to replace some seals. When I hooked up the battery, lights came on in the dash. Started ran good, then turned the key off and kept running. Mine is a stick I just stalled it out and disconnected the battery. Where did you find the wiring problem at? I would appreciate and guidance.
Old Jun 21, 2015 | 1:32 PM
meternerd's Avatar
First, try a little grammar and punctuation....so we old timers can tell what you're asking. You have 12V directly connected to the ignition system somewhere downstream of the ignition switch. You'll need a test light or a multimeter to find the problem. A wiring diagram will help a lot, too. Don't count on wire colors...some previous owner may have done some creative wiring. Fix the ignition problem first, then worry about the running/starting problem. They may be related.
Old Jun 21, 2015 | 3:45 PM
95YukonGT's Avatar
Ok, I was able to fix my no shut off issue. I found the fuse box on the driver side fender, opened it up. Pulled fuses and fount 2 that stopped the power from getting to the coil. 20A Eng and 20A horn. I disconnected the battery pulled the 2 fuses. Reconnected the battery while fuses were out and I heard a click, like a relay in the fuse box resetting. I reinstalled the fuses and problem was fixed.
Newto4x4
May 9, 2013 1:34 PM
jamie
Mar 9, 2011 11:16 PM
compassdave
Jan 15, 2010 11:51 PM
marcss454
Apr 22, 2009 5:48 PM
