1995 Chevy 1500 Vibration at 40 mph
Old Mar 26, 2015 | 1:29 PM
dmancello's Avatar
Post 1995 Chevy 1500 Vibration at 40 mph
My 1995 Chevy 1500 (4.3L) starts vibrating at about 40 mph and I'm running out of ideas for the cause. The vibration occurs whether I'm braking or not braking. The vibration feels to be coming from the front of the truck. I have replaced or had the following done:
-4 new tires (weighted and balanced)
-Alignment
-New tie rod ends
-New pitman arm
-New idler arm
-New wheel bearings
-New brake calipers and brake lines
I also took the truck to a local mechanic and he checked everything that has been replaced and couldn't figure it out. I suggested that maybe the ball joints could be the cause (they are original with 220,000+ miles on the truck) and after he checked them, he said that they were good. Please help...
Old Mar 26, 2015 | 5:05 PM
poncho62's Avatar
Did they check the "U" joints......Might feel like its coming from the front, but vibrations can be deceiving
Old Mar 26, 2015 | 5:36 PM
dmancello's Avatar
U joints haven't been checked. Thanks for the reply. I'll be sure and check.
Old Nov 26, 2023 | 11:28 PM
mals 1995 Silverado's Avatar
Default Mines been doing the same I’m going to change the o Idle Air Control Valve seal clip
-Alignment
-New tie rod ends
-New pitman arm
-New idler arm
-New wheel bearings
. Title
Old Dec 2, 2023 | 10:46 AM
dpieroni3's Avatar
Not knowing the frequency of the vibration. Could it be a tire issue (road force)? Do you feel it in the steering wheel (front end) or the seat (rear) ? Is it a shimmy or a vibration? Could it be duplicated on the lift? Hope this helps isolate your concern.
Old Dec 2, 2023 | 10:50 AM
dpieroni3's Avatar
Could also be drive shaft balance issue. Just a couple of thoughts.
Old Dec 2, 2023 | 4:35 PM
You're replying to a 9 year old topic
Old Dec 2, 2023 | 6:34 PM
dpieroni3's Avatar
I didn't see that. Guess it's time for new cheater's. Thanks
3Hands
Jul 26, 2021 1:36 PM
SUPERULY
Dec 9, 2015 8:38 PM
bigcar
Apr 29, 2009 11:33 PM
mikesmith
Aug 6, 2008 10:03 AM
amos221
Jan 21, 2007 11:04 PM
