1998 Silverado 4x4 Transmission won't shift into Overdrive
Old Oct 11, 2013 | 9:02 PM
SethUpchurch's Avatar
Default 1998 Silverado 4x4 Transmission won't shift into Overdrive
I have a 1998 Chevrolet Silverado that is not shifting into overdrive. It is throwing a code which says that the 2-3 Solenoid is bad, but an auto electrician told me it wasn't bad. I dropped the pan on the transmission today to check and see if the solenoid was still in place and went ahead and changed the fluid and filter. I recently installed a new pcm and that is when my problem started. I had it flashed at the chevrolet dealership and it hasn't shifted into overdrive yet. Does any body have any idea what this could Be?
Old Oct 15, 2013 | 11:09 PM
Tech from Northeastern Transparts's Avatar
Put the original PCM back in. See if the code returns. If code returns its probably a wiring problem ( short or rubbed wire). Is it 3-2 downshift solenoid code or a 2-3 shift solenoid code ? it matters, different parts. Need more info to help you.
snake91876
Oct 13, 2012 3:41 PM
DeezShineyNutz
Nov 26, 2011 8:43 AM
rh6585
Jun 23, 2011 7:54 PM
cb1234wp
Jan 4, 2011 6:02 AM
samuelkowal906
Aug 25, 2009 10:12 PM
