1998 Starting problems DOWN HILL
Old Jul 26, 2011 | 4:35 AM
hd76fxlr's Avatar
Default 1998 Starting problems DOWN HILL
Replaced fuel pump last week; it needed it! Seemed to solve all starting and running problems.Plenty of power, easy starting, etc...
Last sat. I parked it on a hill, over night, with the truck pointed up hill; next morning it wouldn't start.It would try but immediately die.Took my tractor and pulled it to level ground and it started and ran fine ever since.Needless to say I haven't parked it that way over night since.
I thought there was a check valve in fuel pump that would not allow fuel to run back to tank and keeping injection system primed.Is this valve located some where else in the system and is this my problem?
Thanks Charlie
Old Jul 26, 2011 | 7:08 AM
RacerX's Avatar
the problem isnt the fuel pump. it is your fuel sending unit. You only replaced the pump and not the sieve that draws fuel to the pump. So on an incline, the fuel goes to the farthest part of the tank and the sieve is positioned in that area to ensure you always have fuel delivery on an incline, if the tank isnt full. drop the tank and replace the sieve and put in the same way as you took it out.
Old Jul 28, 2011 | 5:33 AM
hd76fxlr's Avatar
Thanks for the come back.My truck is a 1999 not a 1998 as I said.MY BAD!
In 1999 the fule pump sending unit and pick up are all in one unit, you have to replace all at same time.Thanks Charlie
Old Jul 28, 2011 | 7:16 AM
RacerX's Avatar
there you go...
THE_CARNEYS
Aug 21, 2015 1:02 AM
JimNC9
Aug 3, 2011 10:45 PM
kanyons
16
May 17, 2011 11:16 AM
w0by
Jan 19, 2011 12:20 AM
GetYanked
K5 Blazer
Jun 22, 2008 12:03 AM
