2000 Chevy Silverado V6
Old Feb 22, 2010 | 12:18 AM
araiza's Avatar
Default 2000 Chevy Silverado V6
My Silverado leaks coolant and oil. I need to add coolant about every three weeks and oil about every 3K miles. The truck runs fine but I need to fix this issue. Has anyone had this problem ? What is it and how do I fix the problem ? Any suggestions would be appreciated.
Old Feb 22, 2010 | 2:35 PM
nauticstar87's Avatar
Where are the fluids leaking from, what year truck, and how many miles?
Old Feb 22, 2010 | 7:59 PM
ridindirtyv6's Avatar
the v6 have alot of problems with the intake gaskets thats what i would check first if ya dont see it leakin anywhere
Old Feb 23, 2010 | 12:28 PM
araiza's Avatar
Its a 2000 Silverado V6 engine has about 150,000 miles on the engine. Someone suggested the intake gaskets. What do you think ?
Old Feb 23, 2010 | 12:36 PM
gotstylez's Avatar
only way to know is to check it yourself..
Old Feb 23, 2010 | 3:02 PM
ffmed6134's Avatar
Intake gaskets are very common w/ leaking on these motors, You can try the stop-leak stuff from autozone it may help other than that you need to get it looked @
Old Feb 24, 2010 | 11:43 PM
Coppertop71's Avatar
Stop leak will also plug up your heater core first then your radiator, I wouldn't use it unless you dont plan on keeping it. I had a coolant in the oil issue and could tell by looking at the oil fill tube and under the cap you could see all this condensation and water droplets. I ended up replacing my head gasket that is a common problem for the 5.3's though.
I dont think adding oil every 3000 miles is a problem I had a van and added a quart about every 2-3 months it never burnt oil had 40,000 miles on it when we bought it and we put 250,000 before giving it away and the oil consumption was the same through out the time we owned it. Unless you see leaks on the ground you might not have a problem you should be concern with. You can check your plugs and see if any cylinders are burning oil.
Old Dec 21, 2010 | 10:04 AM
bmusic621's Avatar
i used the stop leak in the oil and it worked.
Old Dec 21, 2010 | 10:47 AM
DoubleO7's Avatar
The bad intake gaskets could be quilty for the lose of both oil and antifreeze.
Stop Leak additives are like adding tapioca. The particles swell up, float and around until they find a spot to wedge into.
Such as a pin hole, as well as any other hole that is small enough to capurture the blob of stop leak.
It does not know which holes it is to plug up or leave open.
coldb
15
Feb 12, 2014 10:29 AM
bgkykingpin
Jan 2, 2013 11:39 AM
2000chevyprerunner
Nov 19, 2007 7:35 AM
Chestah
Oct 19, 2006 10:21 PM
