2000 Outside power mirror help fix
Old Jan 16, 2011 | 4:38 PM
paintit's Avatar
Default 2000 Outside power mirror help fix
Both mirrors only move slightly when commanded from the inside button. Can WD 40 or other lubricant be sprayed in the gears to loosen and how do u get to them?
Old Jan 16, 2011 | 7:50 PM
dspla001's Avatar
i would check the gears out before spraying anything on them, could be as easy as a fuse, but WD40 would lube the gears yes. you can access them through the inside of the door
Old Jan 16, 2011 | 8:19 PM
paintit's Avatar
Fuse is good. The gears for the mirrors are inside the door panel?
Thanks for your help..
Old Jan 16, 2011 | 8:45 PM
dspla001's Avatar
no they should be inside the mirror, you can take the mirror off by unbolting it from the door panel
Old Jan 17, 2011 | 5:59 PM
paintit's Avatar
Got it, My weekend project...
randallwise
Oct 20, 2014 1:14 PM
TimmyD
Sep 25, 2013 1:06 PM
tahoe07
May 25, 2009 11:33 AM
bimmerborn
Feb 24, 2008 4:15 AM
dadztoy
Jan 26, 2008 6:02 PM
