2000 Silverado Generator connector on alternator
Old Feb 20, 2014 | 1:28 PM
Pwadwa2012's Avatar
New User
Awaiting E-mail Confirmation
Default 2000 Silverado Generator connector on alternator
Hello to everyone. This forum is amazing. I have a question in an attempt to troubleshoot some electrical issues with my 2000 Silverado Z71. My question relates to the generator connector located on top of the alternator. There is only one wire in this four wire connector. It is positioned second from the right when facing the alternator. I know this is the Charging Indicator Light wire. Now my question.
Should there be 12 volts on this wire coming to the alternator? I disconnected this wire and with the key in the On position or with the engine running, I measure 12 volts. Just curious why voltage would be returning to the alternator.
Any help is greatly appreciated. Thanks again for this helpful forum.
Don.
2000 Silverado, 4x4, 5.3L, Z71, Ext. Cab., 110,000 miles.
Old Feb 21, 2014 | 11:09 AM
runchevyrun's Avatar
That wire is probably the field wire. that will be hot as soon as you turn the ignition switch on or the truck is running. its used to "excite" the alternator. so yes there should be 12v when key is tuned on or truck running.
Old Jul 21, 2014 | 5:52 PM
Pengey's Avatar
Don.
Hello Don, I'm new to the Chevy Forums. I can't find the link to post a question. Since this issue is similar to mine I hope you can respond to my problem. My light glows red on cold mornings, it flickers on and off until my 2001 Silverado V8 reaches operating temperature. The alternator is working that is I have no battery issues. Also I have a home in Palm Springs, CA where it is warm to hot all the time. While in Palm Springs the light never comes on with the exception of starting after a cold night, which can happen in the desert.
It seem to me that it is a connection issue but, where to look? is the question.
Any ideas?
flyoil
17
Oct 31, 2023 2:07 PM
panzaa
Jun 22, 2014 5:06 PM
Xerklite
Apr 27, 2013 9:14 AM
growyoung
Apr 25, 2013 8:50 AM
