2001 2500hd check engine
Old Jan 4, 2010 | 10:19 AM
zman_99's Avatar
Default 2001 2500hd check engine
hi my truck has been running nice and clean when I use it.It has about 31,000 miles.It has been sitting from time to time.the problem started when the battery was dead.fixed that and drove around normally for a while.then noticed i needed oil change,then the check engine light came on.I thought it had to do with needing oil change so I took it in for that.I needed a smog test so I took it there as well.the guy said I had check engine light and I told him when I got oil change they forgot to reset light.Well it didn't pass smog for engine light.the smog guy reset light and told me to drive for 25 miles.did that and took it back for retest.failed again and he told me drive it longer ,till i hit 50 miles.if light remains off bring it back for retest.if light comes on take to mechanic.right about the 50 mile mark the light came on again.what do you think I should do?what could be possible cause?Is it because factory 30,000 mile maintenece needs to be done?please help
Old Jan 4, 2010 | 3:29 PM
nauticstar87's Avatar
scan for codes at your local autozone, then let us know what codes pop up
Old Jan 4, 2010 | 6:41 PM
zman_99's Avatar
Default scan
not to sound dumb,but do you mean if I go to autozone they will scan my truck for problems?is this free or do the charge?
Old Jan 4, 2010 | 7:06 PM
zman_99's Avatar
Default hypertech
I forgot to mention...I think the hypertech power programmer shows some fault codes as well.how extentsive, i'm unsure.would theses be good enough,or just go to autozone.
Old Jan 4, 2010 | 7:11 PM
Autozone does it for free. I'm not sure about the programmer. My knowledge to programmers are limited to Cummins performance for the most part.
31,000miles on an 01 is awesome, i just crossed 19k on mine and I've had it just over a year.
Old Jan 4, 2010 | 9:28 PM
MDTAHOE's Avatar
Professional Mechanic
The check engine light has Nothing to do with maintenance. It means that one of the emissions sensor is seeing a problem and the computer is compensating for it. You need to take to have it properly diagnosed. Codes do not tell you what is wrong only what is being affected.
Old Jan 5, 2010 | 9:15 AM
zman_99's Avatar
I will take it in to autozone today and get an idea of whats going on.I'll post back up in a bit.
Old Jan 7, 2010 | 3:22 PM
zman_99's Avatar
Default auto zone
the auto zone's here in national city ca, don't dothe obd thing here.they said they used to ,and stopped about a year ago!that sucks.guess I will have to take it in to the shop which scares me!hope the best,I guess!
redrotor
Cobalt
Aug 29, 2019 8:38 PM
enderst
Jul 27, 2015 12:38 AM
Henry St-Pierre
Oct 1, 2012 6:52 PM
tkbpainting
Jul 4, 2012 12:38 PM
taterball
Jun 25, 2012 10:14 PM
