2001 Silverado z71 stuck in 4wd
Right now the yellow lights are on for Auto 4wd and 4Hi, but when I drive it's clearly in 4wd. Last night I couldn't get it out of 4lo. I talked to a dealer mechanic and he said it's supposed to change seamlessly when I put it in neutral and press the button, but it doesnt.
Has anyone had this problem or does anyone know a trick to it or is there a way to manually put it back in 2wd?
Thanks,
Daniel W
Thanks,
Daniel W
My 2000 Silverado 2500 with 85k miles is stuck in 4wd lo also. Changed switch and fluid and no change. Mine also won't shift out of first gear. I guess next is encoder motor on transfer case. Right now when I hit buttons nothing happens, no lights. Switch lights do sequence when I turn on ignition. This truck sets idle for months on end. It worked perfect the last time i used it and i might have left it in 4wd lo. but this year i went to hook up to my bike trailer and 4wd lo first gear only.
BigblackHo3
April 5th, 2013 8:54 AM
jmbarnes
November 6th, 2011 12:15 PM
DianaT
November 29th, 2007 12:12 AM
