2001 Silverado z71 stuck in 4wd
Old Dec 10, 2011 | 3:53 PM
DanielW4444's Avatar
Default 2001 Silverado z71 stuck in 4wd
Right now the yellow lights are on for Auto 4wd and 4Hi, but when I drive it's clearly in 4wd. Last night I couldn't get it out of 4lo. I talked to a dealer mechanic and he said it's supposed to change seamlessly when I put it in neutral and press the button, but it doesnt.
Has anyone had this problem or does anyone know a trick to it or is there a way to manually put it back in 2wd?
Thanks,
Daniel W
Old Dec 10, 2011 | 5:34 PM
country_09's Avatar
Could be the switch, or the actuator
Old Dec 10, 2011 | 9:31 PM
high desert jim's Avatar
Better if it is rolling , under 5 MPH, in neutral.
That is what the manual says and it works for mine.
Old Dec 11, 2011 | 12:54 PM
Cabby Jim's Avatar
there should b a slider an the axel....
Old Dec 12, 2011 | 2:34 PM
can I get any more details on this slider? I really dont know what to look for
Old Jan 30, 2012 | 2:07 PM
g9volt's Avatar
My 2000 Silverado 2500 with 85k miles is stuck in 4wd lo also. Changed switch and fluid and no change. Mine also won't shift out of first gear. I guess next is encoder motor on transfer case. Right now when I hit buttons nothing happens, no lights. Switch lights do sequence when I turn on ignition. This truck sets idle for months on end. It worked perfect the last time i used it and i might have left it in 4wd lo. but this year i went to hook up to my bike trailer and 4wd lo first gear only.
BigblackHo3
Apr 5, 2013 8:54 AM
jmbarnes
Nov 6, 2011 12:15 PM
GSJack
Apr 19, 2010 6:05 PM
DianaT
Nov 29, 2007 12:12 AM
mattd17
Jul 8, 2006 11:27 PM
