2004 silverado motor replace/no spark now
Old Jan 27, 2013 | 8:39 PM
novabill's Avatar
Unhappy 2004 silverado motor replace/no spark now
i replaced my 2004 325 motor with another from the same year. i reused most of my sensors and coils from my original motor. the original motor was running just had a knock. my scanner recognizes cam and crank signals, and all guages are working. i had a security light on but did the key cycle on/off to remove it. i have power to the coils but have no spark. i would say its security but as far as i can tell thats cuts fuel not spark. this is on my 2004 silverado and i am at witts end. any suggestions would be appreciated.
Old Jan 28, 2013 | 3:16 AM
branndonn's Avatar
When you try to start your truck does it turn over?
Old Jan 28, 2013 | 11:28 AM
novabill's Avatar
i have no trouble in the motor turning over, and fuel pressure is great.
Old Jan 28, 2013 | 12:32 PM
kevinkpk's Avatar
Ok, can you check for injector pulses? I too believe security cuts off the fuel.
Old Jan 29, 2013 | 9:36 AM
novabill's Avatar
not sure how to do that, can you explain? thank you
Old Aug 14, 2013 | 3:20 PM
novabill's Avatar
all of these problems were caused by grounds not being connected at lower front of the motor and at the back on the passenger side but thank you for your help.
shumajo1
Jan 26, 2011 12:24 PM
cregmonroe
Mar 26, 2008 6:19 PM
