2005 Chevy Silverado daytime running lights
Old Jan 7, 2014 | 3:20 PM
Stanga05's Avatar
Default 2005 Chevy Silverado daytime running lights
The daytime running lights on my 2005 Chevy Silverado came on while engine was off. I jumped it off and ran it to charge the battery but the lights did not go off. A month ago I changed out the headlight switch, which solved the problem for a month but to no avail. Does anyone know how to solve this problem?
Old Jan 8, 2014 | 6:18 PM
JK23112's Avatar
I do not mean to come off as the neighborhood smart-a$$, but you could simply remove the bulbs. You really don't need the DRLs.
Old Jan 11, 2014 | 9:12 PM
Stanga05's Avatar
Default DRLs
Thanks JK23112 for that advice. I''ll do just that and cover the receptacle where the bulbs were removed. GREAT!
Old Jan 13, 2014 | 6:18 PM
JK23112's Avatar
If you remove the bulbs, the 'carrier' in which you insert the bulbs should still be there -- so you probably need not worry about water getting in there. Nobody will know they are missing unless they get up VERY CLOSE and look through the lenses.
I had one of mine burn out recently and am considering removing them myself.
Old Jan 14, 2014 | 3:49 PM
Stanga05's Avatar
Duh! that is so true. guess you can tell what I know about my truck. Ha! You have been most helpful BIG guy. Do have a nice day.
Old Jan 15, 2014 | 12:41 PM
JK23112's Avatar
Perhaps you should switch to decaf, sir. Just sayin'......
RitualJman
15
Apr 22, 2026 9:15 PM
LTZ_HOE
Jul 5, 2025 7:00 PM
troutbum
May 12, 2015 7:45 PM
stingray502
Oct 25, 2006 12:31 PM
