2005 Questions
Old Mar 18, 2008 | 8:40 AM
TravisChamp05's Avatar
Default 2005 Questions
I came from a 96 Silverado and just upgraded to a 2005 5.3L Ext. Cab 2WD and have a few questions/concerns on it maybe some of you can help me out with.
1- When I put the fan control on recirculate (not A/C) it still blows cold. Seems like the same temperature as with the A/C on. Has anyone ever heard of this?
2- The front bump stops over the lower a-arm has a clearance of about 1" or less until it makes contact with the a-arm.The truck is stock height. Is that a normal gap?
I know I have a few more questions, but I'll post as I remember. Thanks for any help/suggestions.
Old Mar 18, 2008 | 10:45 AM
northey87's Avatar
Default RE: 2005 Questions
Welcome to the forum!!! Someone here should be able to help, hang in there.
Old Mar 18, 2008 | 12:23 PM
TransAm Man's Avatar
Are you trying to use the heat when you put on recirculate?
As far as the front end goes, is everything stock?
Old Mar 18, 2008 | 1:03 PM
TransAm,
Thanks for the reply.
On a day that is not real warm, but need cool air not cold, I'll just put the fan on cool setting recirculate w/o a/c. It blows clod just like the A/C would, but A/C light is not on.
As far as the suspension goes, it looks all stock to me.
Old Mar 18, 2008 | 8:57 PM
shawnvw's Avatar
Banned
would you happen to be on the defrost setting?
a\c comes on automatically when in defrost to help de-humidfy the windshield
Old Mar 19, 2008 | 11:51 AM
No, defrost is not on.
Old Mar 19, 2008 | 1:12 PM
It sounds like you have a short in climate control system. I am not too familiar with that particular models system, it either is vacuum, wire, or electronically controlled. This might be far fetched but if you have a junk yard near by, go see if they have the same climate control system you do. You could probably get it for $20, if you were to go to a dealer in would cost around $300
Old Mar 21, 2008 | 9:26 AM
If it will be that cheap, heck I might as well do it. Thanks!
Old Mar 23, 2008 | 6:08 PM
racerx55's Avatar
When you hit recirc button, that turns on the AC compressor if it is set to a cold enough temperature, my 05 Z71 is the same way.
it will blow AC on recircunless you crank the temp contol up some to a warmer setting, then it doesnt call for the compressor to run. Your bump stop gap is normal in the front also. mine touch onthe 072500HD if that tells you anything.
plupien79
Jan 17, 2014 7:55 AM
MadeyeX
Jan 15, 2013 8:30 AM
smith3125
Nov 7, 2008 12:32 PM
Chris420
Aug 12, 2008 4:11 PM
five0_4tluv
Apr 26, 2006 12:59 AM
Top
Follow Us
