2005 truck temp gauge quit working
Old Dec 16, 2010 | 10:10 PM
praaa_5's Avatar
Default 2005 truck temp gauge quit working
My 2005 Chev truck's temp gauge just quit working. When I turn on the key, the gauge needle moves up to about half than drops down to bottom and doesn't move even after the truck has ran for quite some time. I am not sure what happened as it has always worked. Any suggestions on what to look for to fix?
Old Dec 17, 2010 | 3:02 PM
nj85z28's Avatar
Senior Site Administrator
Temp. Sending unit
Old Dec 17, 2010 | 6:57 PM
tsduke's Avatar
Probably temp sending unit. Could be the stepper motor on the cluster though.
Old Dec 17, 2010 | 7:04 PM
6LCHEVYZ71's Avatar
Try temp sending unit first. Thats what it sounds like to me..
Old Dec 18, 2010 | 9:38 PM
praaa_5's Avatar
Is there a way to test the sending unit?
Old Dec 19, 2010 | 8:01 PM
tsduke's Avatar
1.Disconnect the connector from the coolant temperature sensor (temperature sending unit). Measure the resistance across the terminal pins using a digital multimeter and write this value down. Do this before running the engine, it must be cold for this test.
2.Reconnect the connector to the sensor. Start the engine and allow to warm up for two minutes.
3.Disconnect the connector from the sensor again. Measure the resistance across the terminal pins again.
4.Determine the difference in the two readings. If there is not at least 200 ohms difference in the two readings the sensor is dirty or defective.
5.Remove the sensor from the engine if the ohms reading is too low. Clean the sensor, removing any deposits, and repeat the test. Another low reading indicates the sensor is defective and must be replaced.
Old Dec 20, 2010 | 8:15 PM
praaa_5's Avatar
It started working again and I didn't do anything.
Old Dec 20, 2010 | 8:43 PM
DoubleO7's Avatar
Now check the wires from the sender-sensor.
Maybe loose, maybe shorting out on exhaust manifold or some other hot or sharp spot.
Old Dec 23, 2010 | 9:06 PM
GreenBulldogZ71's Avatar
Will it still blow hot and cold out of the vents?
Old Dec 23, 2010 | 9:52 PM
praaa_5's Avatar
Everything works fine with the heater (hot & cold). All is working right since.
