2006 silverado service break system codes c0035 c0041 c00245 HELP!!!!!
Old February 11th, 2008 | 7:57 PM
sierra_5300's Avatar
Default 2006 silverado service break system codes c0035 c0041 c00245 HELP!!!!!
Ok, very long story first i decided to take my truck into the dealer to get the noise in the steering shaft fixed ok everything should be fine nope. I got to reading the service and noticed theydid alot more stuff than what i asked. i saw pcm update on the ticket, i thought to myself oh s**t because i had my hypertech programmer installed i forgot to take it out before i dropped the truck off.well i took it homeand a few miles after i left i get this message in the cluster "service brake system" and the abs and brake light come on great! so i turn around and take it back argue with the guy they take it back in has it for 4 days calls me and says we cant find anything wrong with it. Really! Then they start telling me what custom modifications i have done to the truck is what is cause the service brake system. not even going to go there! anyway they said it could need a new pcm because the hypertech program that was still in it effected the update they did and is causing the problem and of coarse they wont warranty it because i left the program in there. ok so i go home take matters into my own hands. i use the hypertech programmer to see what codes it brings up c0035left front wheel sensor, c0041 right front wheel sensor, and c0245 wheel speed sensor frequency error. wheel sensors are working to specs as they should all connections are good including the abs plugs. I didnt know what else it could be so i decided to buy a new pcm, came in, installed it. guess what same sh*t!! i have not idea. I noticed however when i clear the codes with my programmer and the second i turn the key off and turn it right back on without starting it or driving it any where the codes are in the computer again. I am leading towards the abs module but i would be guessing. any info would be greatly appreciated tired of the crap on my instrument cluster.
Old February 11th, 2008 | 9:34 PM
06chevy5.3's Avatar
Default RE: 2006 silverado service break system codes c0035 c0041 c00245 HELP!!!!!
if you remove the download and put it back in will it reset it?
Old February 12th, 2008 | 7:54 AM
they hypertech, with it in or out it doesnt matter i still get the trouble codes, what ever the dealer did they screw up a module somewhere as soon as i drove it away from the dealer those lights came on and i didnt drop it off like that
Old February 12th, 2008 | 8:28 AM
06chevy5.3's Avatar
thats a tuff one. do you know if they flashed any other modules?
Old February 12th, 2008 | 9:16 AM
not sure all that was on the service ticket was update pcm. i asked him why he did that all i wanted was the steering shaft fixed he said it was a required update for the e85
Old July 5th, 2010 | 9:22 AM
1500Z712006's Avatar
Default some problem
I have had the same thing happen and in addition my truck has P0101, P0171, P0174. I have no idea what to do. I have a aftermarket mass air flow sensor. the codes keep coming back... is there a way to have it fixed? or at least make sure the system is working correctly?
Old December 9th, 2010 | 10:32 PM
jwise04's Avatar
Default Same Problem! co 245
Any solutions yet to this problem? I have an 06 Equinox and ABS/TC lights are on... getting wheel speed frequency error. I have mechanics telling me that I have the wrong size tires on the car. They said the car needs to be programmed for those size tires. I just find this hard to believe because i have had these same sized tires on here for 18 months and NO PROBLEMS until now. Getting code number 245.. Please help!
uplander06
Uplander
October 2nd, 2022 5:43 PM
cdnskipatroller
Uplander
26
September 25th, 2017 2:31 PM
valkire17
September 11th, 2010 9:35 AM
jermacjr
27
February 19th, 2008 4:33 PM
martinjp
11
December 4th, 2006 10:14 AM
Quick Reply: 2006 silverado service break system codes c0035 c0041 c00245 HELP!!!!!
