2007 chevy silverado vortec max.
RE: 2007 chevy silverado vortec max.
Yes it is, but you have to order Stabilitrak JL4. Look at NADA bood and read under the 6.0 engine.
ENGINE, VORTEC 6.0L VARIABLE VALVE TIMING V8 SFI WITH ACTIVE FUEL MANAGEMENT,
(367 hp [273.7 kW] @ 5500 rpm, 375 lb-ft of torque [506.3 N-m] @ 4300 rpm), includes (KC4) external engine oil cooler, (KNP) auxiliary external transmission oil cooler, (AXN) heavy-duty 9.5" (24.1 cm) trailering axle and a door badge that reads "Vortec Max"Also includes (JD9) Brakes when (JL4) StabiliTrak is ordered.
Manufacturer Code: L76
$830
$1,000
$830
$1,000
I am not sure about the trailering package or the 4 wheel disk brake,. I know that mine comes with it. I have a 2007 VortecMax and i am still learning about it.I do have StabiliTrak also.
[align=left] [/align]
To make things simple the JD9 option (4-wheel ABS and 4-Wheel Disc brake) is included along with JL4 (Stabilitrak) when the the L76 (6.0L Vortec Max) option is ordered.
Meaning simply that you cannot get a 6.0L 1500 Silverado without Stabilitrak or rear Disc Brakes.
I do have a 6.0 Vortec MAXSilverado without disc brakes on the rear. When my dealer ordered the truck heforgot to order StabiliTrak and the truck came in with rear drum brakes. If you want the 6.0 order the StabiliTrak.
Old Coot,
I should clarify that on Crew Cab trucks you can't get the Vortec Max without Rear Disc Brakes but on Extended Cab models you can.
Sometimes I forget to check spec on the Ext Cab's due to the market on Crew's.
daspokerman
April 24th, 2009 4:52 PM
akcirocz
July 27th, 2008 9:10 PM
eric2007ltz
March 5th, 2007 10:58 AM
