2007 chevy silverado vortec max.
Old Jul 25, 2007 | 9:35 PM
reesekeen's Avatar
Default 2007 chevy silverado vortec max.
Is it possible to get 4 wheel disc brakes on the 2007 chevy vortec max without getting the max trailering package?
Old Jul 26, 2007 | 6:22 AM
Old Coot's Avatar
Default RE: 2007 chevy silverado vortec max.
Yes it is, but you have to order Stabilitrak JL4. Look at NADA bood and read under the 6.0 engine.
ENGINE, VORTEC 6.0L VARIABLE VALVE TIMING V8 SFI WITH ACTIVE FUEL MANAGEMENT,
(367 hp [273.7 kW] @ 5500 rpm, 375 lb-ft of torque [506.3 N-m] @ 4300 rpm), includes (KC4) external engine oil cooler, (KNP) auxiliary external transmission oil cooler, (AXN) heavy-duty 9.5" (24.1 cm) trailering axle and a door badge that reads "Vortec Max"Also includes (JD9) Brakes when (JL4) StabiliTrak is ordered.
Manufacturer Code: L76
$830
$1,000
Old Jul 26, 2007 | 1:27 PM
blackmax's Avatar
I am not sure about the trailering package or the 4 wheel disk brake,. I know that mine comes with it. I have a 2007 VortecMax and i am still learning about it.I do have StabiliTrak also.
[align=left] [/align]
Old Jul 26, 2007 | 1:55 PM
ZX1100F1's Avatar
To make things simple the JD9 option (4-wheel ABS and 4-Wheel Disc brake) is included along with JL4 (Stabilitrak) when the the L76 (6.0L Vortec Max) option is ordered.
Meaning simply that you cannot get a 6.0L 1500 Silverado without Stabilitrak or rear Disc Brakes.
Old Jul 26, 2007 | 2:49 PM
Old Coot's Avatar
I do have a 6.0 Vortec MAXSilverado without disc brakes on the rear. When my dealer ordered the truck heforgot to order StabiliTrak and the truck came in with rear drum brakes. If you want the 6.0 order the StabiliTrak.
Old Jul 26, 2007 | 3:13 PM
ZX1100F1's Avatar
Old Coot,
I should clarify that on Crew Cab trucks you can't get the Vortec Max without Rear Disc Brakes but on Extended Cab models you can.
Sometimes I forget to check spec on the Ext Cab's due to the market on Crew's.
daspokerman
Apr 24, 2009 4:52 PM
akcirocz
Jul 27, 2008 9:10 PM
akcirocz
Jul 9, 2008 9:52 PM
07max
Aug 30, 2007 4:04 PM
eric2007ltz
Mar 5, 2007 10:58 AM
