2008 Silverado, Big Electrical Problems
Old Aug 16, 2011 | 8:19 AM
BZ Man's Avatar
Default 2008 Silverado, Big Electrical Problems
Hi Everyone,
I just bought a 2008 silverado LTZ Crew Cab Vortec Max about a month ago certified used with only 34,000 miles on it. Everything was fine with the truck until one day I tried to start it and it cranked like normal until it got to the point to where it would normally start and then the starter started grinding and the motor was kind of half started like it was missing. took it to the dealership and the couldn't find anything wrong with it. Four days go by with no prbolems and now I try to start it this morning and the same thing happens except for now there is rapid electrical ticking sound comming from under the hood and the gauges start flashing at the same pace as the ticking sound. I shut the key off and tried to start it again and the starter made the grinding noise and it did start. It drives fine after it is started and there are no other electrical issues that I have noticed while driving. I am at a loss, please help
Old Aug 17, 2011 | 1:06 PM
Official GM Rep
I can also look into this for you. In order to do more research, I will need some more specific information from you such as your name, address, phone number, the VIN for the vehicle, current mileage, and dealer name. If you have further questions, please feel free to contact me either on the thread or via private message. Thank you.
Tricia, GM Customer Service.
Old Aug 17, 2011 | 3:07 PM
kevinkpk's Avatar
Originally Posted by BZ Man
Hi Everyone,
Sounds like a loose connection to me. I would look at the starter.
Last edited by kevinkpk; Aug 17, 2011 at 3:16 PM. Reason: I would look at the starter
Old Aug 23, 2011 | 10:35 PM
Finback's Avatar
Change the positive battery cable end at the battery. That was the trouble with my '08. Looked great from the outside but it was burned inside the crimp.
Old Aug 24, 2011 | 6:57 AM
BZ Man's Avatar
It's still a little early to tell if I fixed it or not, but on Sunday I took a look at the starter and the connections looked pretty dirty and starting to corrode so I unhooked the battery and unhooked two of the three connections at the starter (couldn't get the farthest back connection off) and cleaned them up with a wire brush and hooked everything back up and so far so good. It's been four days now without a problem, but as intermittent as the problem was happening I am reluctant to say it's fixed yet.
blktrk4man
2007 - 2013 (GMT900)
109
Nov 15, 2022 7:21 PM
Tondojr9
Sep 11, 2020 12:48 AM
G P Meyers
Uplander
77
Apr 15, 2020 2:37 PM
silberm3
Jun 30, 2011 7:32 AM
obby121
Feb 12, 2011 1:29 PM
