2010 Sierra Z71 1500 security light sometimes and no start
Old Sep 9, 2011 | 11:01 PM
A. T's Avatar
Default 2010 Sierra Z71 1500 security light sometimes and no start
I know it's a Chevy forum, but I was already a member and they are the same trucks.
My aunt's boyfriend has a 2010 Sierra Z71 (bought new almost year ago), it has almost 40k on it. It also has the factory remote start. He started to have an intermittent starting issue on Thursday.
If you hit the lock button once and the security light, lights up on the dash the remote start will not work when the lock button is hit for a second time. If the security light doesn't light then the remote start works.
Then with the key. If you turn the key on and the compass (locatated in the odometer area with the temp) has the dash marks light it never got calibrated and if that happends it won't start. But, if the compass works it starts.
Has anyone seen this problem before? Do you think the fix will be covered under warranty?
Thanks
Old Sep 10, 2011 | 12:20 PM
Mille Racer 69's Avatar
it is definitelly still under warranty.
just take it to them and let 'em have a look-see
Old Sep 11, 2011 | 3:24 PM
A. T's Avatar
Even with 40,000 miles? What is the electrical warranty?
Old Sep 15, 2011 | 7:48 PM
A. T's Avatar
I was able to borrow the Snap-On Solus from work to get the code. I found a U1511. As far as I know, the trunk isn't under warranty anymore.
Old Sep 16, 2011 | 8:44 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> A.T
The parameters for warranty are; 3 years/36,000 miles whichever comes first. The 2010 is definitely in the years, so if the vehicle has less than 36,000 miles the truck is under warranty still.
Breanne
Chevrolet Customer Service
Old Sep 17, 2011 | 6:19 AM
A. T's Avatar
It also starts every time by hold the headlight switch to the left while turning it over.
Old Nov 29, 2011 | 4:35 PM
A. T's Avatar
He took the truck to the dealer, and they hooked him up. They covered it under warranty because of other trucks with the same problems. What was found was corrosion in the under hood junction block. A friend of mine that works for GM as a tech that helps dealers diagnose vehicles, told me he has seen corrosion there usually on a truck that has been crashed.
BucMan55
Jul 8, 2017 8:54 AM
joshrichards182
Aug 11, 2015 3:11 AM
02suburban
Jan 19, 2015 12:33 PM
danielGTP10
Sep 27, 2011 8:43 PM
wildboy74ss
Apr 1, 2009 5:10 PM
