2010 Tahoe hvac issue
Old Jan 13, 2022 | 12:22 PM
tfcole1's Avatar
Default 2010 Tahoe hvac issue
I was having an issue where my front a/c would only blow at high speeds, then it went out completely. I read that changing the resistor would help, so I replaced it, but it didn't fix the isssue. Neither did replacing the blower. I replaced both and now it'll blow, but it's stuck in high speed and won't shut off even after I turn the engine off. It's odd because the same **** controls the rear a/c and it does just fine. Any ideas?
Old Jan 13, 2022 | 2:51 PM
Welcome from Florida. You might have a stuck relay for the blower motor. Try changing them around only with another one one with the same part number. If the problem moves to the other location you have a bad relay.
jerryjerry05
Oct 13, 2018 1:00 PM
Lacy24231
Jan 19, 2016 7:47 PM
BillMartin
May 8, 2015 11:25 AM
xbigblue
Jan 15, 2012 5:19 PM
gardnersmith
Jul 22, 2008 10:11 PM
