2014 Emergency Brake mechanism.
Old Apr 28, 2014 | 3:33 AM
Mr. Bojangles's Avatar
Default 2014 Emergency Brake mechanism.
Wanted-Discussion regarding the 2014 silverado EMERGENCY BRAKE mechanism's method of working:
Hello:
If I leave my Emergency Brake on and drive, a alarm (beeping i think) goes off. THIS IS GOOD (Drove my Dodge Tooo often with brake on).
How does the mechanism work? I mean, does the drive system sense the initial resistance to movement? Help? I know someone knows, and can explain in simple words.
Old Apr 28, 2014 | 8:10 PM
here's my guess...the ebrake foot pedal grounds a signal wire when the brake is applied. the bcm knows the ebrake is applied when the voltage on this wire goes low. the bcm then sends a message via the data lines to sound the chime warning in the radio and warning light in the ipc.
Old Apr 29, 2014 | 4:03 AM
Thank ya TECH2.... anyone else........???
Old Apr 29, 2014 | 7:34 AM
Tech2 gave it the best and probably the most correct way.... I'll nut shell it to its probably a switch on the E-brake peddle...
bigb
Aug 12, 2013 8:56 PM
gramps2one
May 3, 2011 9:29 AM
rab87
Nov 8, 2007 12:07 PM
diane888
Aug 5, 2007 9:46 PM
geepee1
Jun 11, 2006 11:48 AM
