2014 silverado lt
Old Feb 18, 2015 | 3:52 AM
BeakerFTWnDiablo's Avatar
Default 2014 silverado lt
Yesterday 09:36 AM by BeakerFTWnDiablo
Hello,
Im new to the chevy forum. I recently purchased a 2014 silverado LT w short bed V8 n 4x4. I want to lower the rear to match the front level instead lifting it. How much is that? 2 inches?
Another question is WHICH METHOD? Remove rear block or shackles or lower kit or what? Whichs the best method?
Thanks
Beaker
Old Feb 19, 2015 | 7:58 PM
country_09's Avatar
Easiest is remove block, but will be about 1.25" lower if you do that. Pull em and see how you like it, if not enough, then do shackles
Old Feb 20, 2015 | 6:45 AM
Do I need to change the shocks or leave it as it is after pulling the block n if needed shackles.
Thanks
Old Feb 20, 2015 | 10:06 AM
country_09's Avatar
Shocks will be fine with either application, but if you feel the need, change them out with some beltech shocks and ride
Old Feb 25, 2015 | 7:11 AM
Cowpie's Avatar
Can't speak to the 1500 but my new 2105 2500HD I am using a set of spring shackles from McGaughy's to lower the back 2". $60 for a set of shackles on my 2500HD.
Just found them for you at McGaughy's.... $46 for a set of rear shackles to lower 1" or 2".
Chevrolet Silverado 1500 2014-2015 Rear 1"-2" Drop Shackles - McGaughys Part# 33037 - Mcgaughys-Suspension.com
Supashack
Corvette
Aug 26, 2014 6:27 PM
2004MaxxLT
May 15, 2014 3:14 PM
Chevrolet Forum News
Jan 18, 2014 11:08 PM
Jan 17, 2014 10:08 PM
blueinterceptor
Jan 5, 2014 8:40 AM
