2018 Silverado 1500 Ignition won't turn - Help needed
Old Feb 6, 2023 | 6:24 PM
millwright1178's Avatar
Exclamation 2018 Silverado 1500 Ignition won't turn - Help needed
My ignition switch won't turn it happened with out any prior indication of trouble, i bought it new and never had too many problems, both key are in good condition with no bends or wear, both still work in the door lock perfectly. I took the column housing off and i notice this small cable that goes into the ignition housing just below the cylinder lock housing. My question is what is this cable ( possibly a park / neutral safety device) ? Is there something else that i could possibly check before spending a bunch of money on a new ignition switch.
I have been looking on the web most of the day for information on this problem or even a schematic of the mechanical components and mechanical safety devices for this year and model truck but have not found much. late 2013 to 2018 models should all be the same i have had a couple of these trucks so far and never had this issue.
Old Feb 6, 2023 | 6:45 PM
90% of the time it is the key. worn keys will work in the door as the door cylinders have 2 less tumblers. if the edges of the keys are rounded or the silver is worn off...its probably the key.
don't trace old keys...have new keys cut from a code.
Old Feb 6, 2023 | 7:03 PM
One key was never used as I bought the truck new and it won't work either .
Trichiro
Nov 17, 2020 10:23 PM
Rebecca Norton
Oct 26, 2018 12:36 PM
jameszr2
Oct 19, 2018 10:54 AM
dsbodley
Nov 21, 2015 6:16 PM
sleekpete
Aug 28, 2010 5:22 PM
