4 Wheel Drive
Old Nov 19, 2012 | 11:31 AM
jewels64's Avatar
Default 4 Wheel Drive
Have a 2007 /1500 Work truck, the 4 wheel drive won't engage when it's below freezing, shift is on the floor, transfer case is going into 4 high and 4 low. It has to be put in a garage or temp in 50's to start working.
Old Nov 19, 2012 | 12:38 PM
Fishinfooleric10@aol.com's Avatar
So are you saying that the truck is saying it is in 4 high or 4 low but is not really engaged.
Old Nov 19, 2012 | 1:32 PM
jewels64's Avatar
It will not engage in 4 wheel drive when it is freezing out. stays in 2 wheel no light on. transfer case engages 4 H 4 L but not the front end til its warmed
Old Nov 20, 2012 | 7:42 AM
ericnottelin's Avatar
Does the transfer case engage? IE when you shift it in 4h, and you look under the truck, does the front shaft spin? If so, you may have a problem w/ the engaging mechanism inside the pumpkin of the front axle.
Old Nov 20, 2012 | 12:53 PM
jewels64's Avatar
Have to wait til it gets cold enough to check. Thanks
Billy HC
Dec 10, 2018 1:59 AM
Metrostar
Mar 4, 2011 9:42 AM
Jaysonic
Mar 8, 2010 9:07 PM
mntnpagan
Nov 29, 2005 2:03 PM
whitcre
Aug 20, 2005 12:26 AM
