4l60e
I have a 1995 Silverado 2wd. The tranny went out at 282K. I bought a tranny from a friend that matches up except for the neutral safety switch is different. Mine is located on the shifting shaft and the one I bought must be out of a 94 or older. Is there anything I can do to make this work?
Thanks
Thanks
I don't know what can be done. I know the plug at the bottom is for back up lights. but the upper plug has 4 wires going to it and I dont have a clue what they are for. I'm use to the older Turbo 350/400's, before all of this electronic stuff.
[QUOTE=cb1;224905]I have a 1995 Silverado 2wd. The tranny went out at 282K. I bought a tranny from a friend that matches up except for the neutral safety switch is different. Mine is located on the shifting shaft and the one I bought must be out of a 94 or older. Is there anything I can do to make it work?
If you are able to plug it in put the vehicle in natural and try to start it if it turns over and and starts then the nss is good
abqgolfer
August 27th, 2011 11:30 PM
oppelousas
July 25th, 2007 1:46 PM
dragondad
January 1st, 2007 3:27 AM
